New starter
+2
6 posters
Page 1 of 2
Page 1 of 2 • 1, 2
New starter
After breaking the new mini starter that i bought i decided to try the old starter again,was a bit hit and miss,sometimes it would turn over slowly and sometimes fast enough to start.When it was turning over it was loud and i though it might need shimming so added some,then it stopped turning engine over,so bought another standard one.
Here's my old one when i took it off,i say old,it's actually only about 12 months old.
Here's the new one off ebay from USAuto,only £55 delivered.Still have same problem though with slow and fast turning and noisy.Not sure if it needs more shims,already got about 7 shims in there.
Bandit- Posts : 334
Re: New starter
i had one one my 400 had it off and never really knew if i put it on right either . turned it ok tho
thirdgen- Posts : 1627
Re: New starter
My car has its original starter when it got a bit lazy I put an extra Earth on it that sorted the problem 14years ago and it's still going strong
Terry-D- Admin
Re: New starter
headers are the problem with standard ones i think no other reason to change it i would have thought
Re: New starter
I thought it was a header problem at first that's why i bought the mini one,although headers are wrapped,i put a earth cable from chassis to one of starter motor bolts but that didn't help either.
Seems odd i have only had this problem since the engine wouldn't turn at all and i found the washer against the push rod.
Bandit- Posts : 334
Re: New starter
I didn't think of that Paul and I am going to be getting headers .
Terry-D- Admin
Re: New starter
Bandit wrote:I thought it was a header problem at first that's why i bought the mini one,although headers are wrapped,i put a earth cable from chassis to one of starter motor bolts but that didn't help either.
How did that get there?
Terry-D- Admin
Re: New starter
I have had headers on nearly all of the birds i have had,never had a starting problem with any of them.
I think my car is jinxed,think i need to stop buying cars off dead people lol.
Bandit- Posts : 334
Re: New starter
Terry-D wrote:Bandit wrote:I thought it was a header problem at first that's why i bought the mini one,although headers are wrapped,i put a earth cable from chassis to one of starter motor bolts but that didn't help either.
Not a clue,looked like one of the washers off the intake bolts which i had off a few weeks before but they all have their washers in place.
Bandit- Posts : 334
Re: New starter
christine ?? that one fixed it self didnt it
i would stick with manifolds if i was you terry
Re: New starter
Bloody washers have a mind of their own
Terry-D- Admin
Re: New starter
May just do that thanks Paulthirdgen wrote: christine ?? that one fixed it self didnt it
Terry-D- Admin
Re: New starter
The mk4 Continental was a bit like Christine,didn't fix itself but one owner killed himself in it,sat in it drinking a bottle of whiskey with a pipe from exhaust into car.Next owner parked it on Ainsdale beach nr Southport and tide came in on it,i guess that's why it always sounded like it was running on water,lol.Then i bought it but decided it needed too much so sold it to the Blues brothers in Crewe.They towed it back with a wagon but it wasn't running,the one steering it had igbition on to use lights,but then it started to rain so he had wipers on,then battery went flat just as they were going over a hump back bridge,on the other side of the bridge was a almost new Rover,the guy driving the wagon went round it but the one in the Lincoln couldn't see it and ploughed straight into it,wrote both cars off.
Was glad to get rid of that one
Bandit- Posts : 334
Re: New starter
lol thats one car i would not want anyway the hose pipe would have put me off
Re: New starter
they really do improve performance and throttle response a lot though
was amazed how much faster mine was after fitting them. wrapped mine and the starter, and never had a problem
Re: New starter
Put them on my gta i did nit notice any dufference apart from a nicer rumble
Re: New starter
Definitely noticed a difference when fitted, like dad said better pick up, better throttle response and better noise
Re: New starter
SUPERCHARGEDGTA wrote:thirdgen wrote: christine ?? that one fixed it self didnt it
Kevs got nothing to do he's good with a spanner
Terry-D- Admin
Re: New starter
thought he was busy making trouble on the poc forum
Re: New starter
My mini didnt have any shims...worked fine
Webbel- Admin
Re: New starter
last one I fitted only needed 1 shim
Re: New starter
you sure its got the right flywheel/flex plate?
is starter ring ok?
is starter ring ok?
Re: New starter
With the starter that just broke i am sure i had 3 shims and never had a problem with it for about 12 months,then i had the starting problem when i found the washer in the head.
The flex plate is same one that's been on from when i fitted the 400 engine,i have been thinking maybe it's warped from when i was messing around trying to get the mini one to work,but wouldn't think that would affect shimming,but maybe it's what's making it noisy turning over,i just assumed it's a shimming problem.
Bandit- Posts : 334
Page 1 of 2 • 1, 2
Page 1 of 2
