Dayvan heater leak
+2
6 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Dayvan heater leak
So,the leaking heater rad in my Chevy Dayvan didn't seal up after I put a can of K-Seal stop leak stuff in it so it has to come out.
Manual and guys online say - to remove heater rad first remove entire dash(or undo all fixings and prop it up
I removed it completely.
Then they say - undo hoses and remove three nuts from from under hood and one bolt from inside van.
Heater box can then be removed from inside van and you can get to the heater matrix.
Yeah,right,lol. What about the umpteen other nuts,bolts,clips,trunking etc that are still holding it in !
Will finish removing it later this week
To be continued
To be continued
TABlazerG20- Posts : 108
Re: Dayvan heater leak
Wow sounds like great fun mate
Not the best time of year for that job. ..good luck
Webbel- Admin
i would just pipe it up together for now loose the heater until summer
thirdgen- Posts : 1627
not sure why you would want to go all winter freezing your arse off without a heater then fix it for the summer so you can sweat your ring off
better to fix it now while you need it
Cos its too cold to work on motors until spring lol
He needs to get it working as it is the Rebel support Van for us all to hide in while it is raining at meets lol
indeed
half the year its too cold, rest of the time its too hot
Sod driving around all winter with no heater working Paul. Maybe it's warmer in winter in Suffolk than it is down here in Essex though,or maybe you're part Eskimo and don't feel the coldthirdgen wrote:i would just pipe it up together for now loose the heater until summer
divvy has no heater in his cut and shut for years
Finally got heater core of of Dayvan,after disconnecting/removing loads more stuff. Inside of Dayvan now looks a right mess,lol.
Took leaking heater core to Radiator place but they wanted about £300 to put new core in it,seems american rads use a different sort of core than others. He did show me the difference but sod paying that much for a rebuilt heater rad !
Just ordered brand new one from Summit Racing -heater rad was only about £23 and with duty and shipping (used their I-Parcel direct to my door all duties paid service) came to about £60 and should be here next week. Added couple of oil filters to order while I was at it which worked out around £4 each and didn't add much to shipping cost.
All I have to do when it gets here is remember how everything goes back together again
So much fun
jealous----------not!
sorry did not have time to talk for long Paul, mad patch
No worries John,was passing so thought i'd pop in,had just been to take back something to Screwfix place along road from you.SUPERCHARGEDGTA wrote:jealous----------not!
Us Rebels don't need manuals,we just work out how things come apart and remember how they go back together again - sometimes everything works afterwards too,lol.Webbel wrote:You got a manual for it Paul ?
I do have a Haynes manual for it somewhere mateWebbel wrote:Ive got a manual if you want it
Thanks for the offer mate If yours is not a Haynes one and I get stuck i'll get back to you.Webbel wrote:Ive got a manual if you want it
Should get it all back together again ok though as i've had dash out before a couple of times some years back so I should remember where everything goes
I wouls probably do the same as you have ripped it out then worty about it lol i like it warm too had enough of the cold already ..
Page 1 of 2 • 1, 2
Page 1 of 2
